Replacing coils on spark plugs
LSG
Sanford
Hi, I recently had a coil No. 4 to misfire. I need to know where this is or does anyone have a schematic/diagram because the coils are not numbered. Any help is needed and greatly appreciated.
stand in front facing the car ...start from your left cyl #1 being the closest to you then 2 3 4. then cyl 5 is closest to you on the right. then 6 7 8.
This is what Lincoln dealer's mechanic told me. Also if you have misfire check if there any oil down the spark plug well...if yes you also need to change the valve cover gasket also. I gonna change my this weekend
