Replacement FOB
Lincoln LS
  1. 04creamlsv8
    04creamlsv8 LVC Member
    43
    Dec 22, 2009
    Prescott
    Hey guys, does anyone know of a RELIABLE website to order a replace keyless remote?? The dealer wants close to $100 but a couple websites I found have them for under $30 plus shipping...Any suggestions? comments? advice?
  2. Mechanicboy
    Mechanicboy Dedicated LVC Member
    1,409
    3
    Nov 18, 2009
    Durham
    Well the reliability depends upon the seller you can get key-fobs on ebay for $15 or so shipped. You will have to program it to your car which I'm told isn't very hard.
  3. gcwimmer
    gcwimmer Dedicated LVC Member
    2,647
    Nov 17, 2006
    Reno, NV
  4. NYC LS8
    NYC LS8 Dedicated LVC Member
    8,334
    15
    Mar 9, 2004
    Carpentersville, IL
    I've gotten them from eBay for every car I've had that needed them.
  5. Alax7
    Alax7 Dedicated LVC Member
    7,816
    38
    Dec 18, 2008
    LA
    I would say ebay. The programming instruction are in your manual and its not that hard. Oh but you do need 2 programed keys to program more keys.If you only have 1 you probably need to get another at the dealer to programm your own. If you do have 2 already programmed keys you just insert one key in the ignition, then the second, then the new unprogrammed key. Not exactly like that but thats just the the overall big picture.
  6. 04creamlsv8
    43
    Dec 22, 2009
    Prescott
  7. gcwimmer
    2,647
    Nov 17, 2006
    Reno, NV
    It is an OEM fob, why pay more, I buy mine on ebay. As long you buy the right fob for your 2nd gen LS as compared to 1st gen fob.
    As long as both key's are already program you have enough key's to add and program more keys on your 2nd gen LS. Again I have bought OEM blanks on ebay, had them cut at Lowe's and programed all of my keys myself using one regular and one valet key. The only difference between a regular key and the valet key is the the valet teeth are not cut as deep.
  8. 04creamlsv8
    43
    Dec 22, 2009
    Prescott
    alright then sounds good. i'm gonna order it tonight. thanks guys
  9. Alax7
    7,816
    38
    Dec 18, 2008
    LA
    You just need 2 keys. You can use a valet and and ignition key
    *EDIT: Well just like gcwimmer said, sorry for the double reply*
  10. Silver_LS
    Silver_LS Dedicated LVC Member
    1,333
    Mar 11, 2008
    Maple Lake, MN
    :D Ebay
  11. joegr
    joegr Dedicated LVC Member
    19,946
    1,507
    Dec 10, 2005
    Gulfport
    I think that the confusion here is about what you are trying to do. My thought (though now I am not so sure) was that you were looking for a replacement remote. They seem to think that you are looking for a replacement key.
    To program a new key, you will need two working keys.
    To program a new remote, you only need one key.
    In either case, the procedure is different, but both are listed in the owner's manual, and are pretty simple.
  12. 04creamlsv8
    43
    Dec 22, 2009
    Prescott
    Yes thank you joe. I need a replacement remote which I ordered a few hours ago. I thought thats what the FOB was?? Maybe I was mistaken. However it's all cleared up now.
  13. Alax7
    7,816
    38
    Dec 18, 2008
    LA
    Oh sorry. Just read key in people replie and it just passed me :confused: . Haven't look into how to program a control. By the way what does FOB stand for in key fob
  14. gcwimmer
    2,647
    Nov 17, 2006
    Reno, NV
    A item at the end of a tether or chain that goes into a pocket, pocket watch fob, key fob or in this case, remote fob.
  15. joegr
    19,946
    1,507
    Dec 10, 2005
    Gulfport
    How to reprogram your remote entry transmitters
    You must have all remote entry transmitters (maximum of four)
    available before beginning this procedure.
    To reprogram the remote entry
    transmitters:
    1. Ensure the vehicle is electronically unlocked.
    2. Put the key in the ignition.
    3. Turn the key from the 1 (LOCK) position to 4 (RUN).
    4. Cycle eight times rapidly (within 10 seconds) between the 1 (LOCK)
    position and 4 (RUN). Note: The eighth turn must end in the 4 (RUN)
    position.
    5. The doors will lock, then unlock, to confirm that the programming
    mode has been activated.
    6. Within 20 seconds press any button on the remote entry transmitter.
    Note: If more than 20 seconds have passed you will need to start the
    procedure over again.
    7. The doors will lock, then unlock, to confirm that this remote entry
    transmitter has been programmed.
    8. Repeat Step 6 to program each additional remote entry transmitter.
    9. Turn the ignition to the 1(LOCK) position after you have finished
    programming all of the remote entry transmitters.
    10. The doors will lock, then unlock, to confirm that the programming
    mode has been exited.
Share This Page
