HELP!
im pissed off man I have the same problem.
I just hooked the remote wire up to one of the fuses in the trunk, but now my amp is on all the time. and my battery is slowly draining unless I pull the fuse from my amp when i turn the car off.
I NEED TO FIX THIS ASAP.
I was unaware of that as I am still learning this vehicle.most relays need +12v to turn on, ford amp turn on is only about +6v, so you would need a low voltage relay like the TR-4 that PGA2b posted
