RigsLS
- Joined
 - Mar 10, 2012
- Messages
 - 7,734
- Reaction score
 - 523
I would honestly be surprised if one single part was interchangeable between these two completely different cars.
Possibly the glove box bulb?
Would like the rearview mirror if it is autodimming.
Are the wheels the diamond spoke laced wheels, and if so what size?
wrong car, these are not the same, they are not interchangeableLittle hope for a differential matchup either.
totally the wrong car dude, nothing is interchangableDon't think any of the body parts swap either.
I wanted to jump up quickly in case anything did work.
I will be checking with my contact at a FoMoCo parts counter to see if they are interchangeable.
But if it is, there is a good chance that at least those parts might swap.
However, I am still hot on the trail
.... And I wanted to jump up quickly in case anything did work.
However, I am still hot on the trail of an H-pipe and driver side tailpipe, muffler and hangers. I will be checking with my contact at a FoMoCo parts counter to see if they are interchangeable.
Any chance of getting the VIN on this vehicle so I can have a parts lookup run? Thanks.
If the car is not dual exhaust, forget the whole thing. But if it is, there is a good chance that at least those parts might swap.
And as to the wheels, I realize the diameter is probably larger, but I am considering putting larger (maybe 16 or 17s)...or do the LS not have the 5x14.5 with 70.5mm centerbore? I am planning on putting on larger hubs in order to put the larger rotors on the front, but not looking to go to a different basic pattern.
Don't feed the troll guys....
...But I do think that there is at least a chance that an autodimming mirror, with or without a compass and with or without a temp display, might fit, even if the body and frame are entirely different. ...
So was that a no on the bolt that holds down the spare tire and jack to the trunk? LOL
Thanks for the wheel info. I was unaware until now that it wasn't the other size.
And since I just happened across the LS section of LincolnvsCadillac after scrounging up some tech articles, honestly I wasn't aware that the LS was so Jag like until it was pointed out to me. Though I have to say I see little similarity of a modern LS to either my former 1961 Mk II with the the 3.8L sedan in British racing green, with wire spoke wheels and knockoff hubs.
Nor does it resemble (even mechanically, forget styling) either the E-Jag or the XK140.
The MkII had a BorgWarnerStudebaker auto trans with a really nice feature that later Jags lacked...press the brake at a light, leaving it in gear. Brakes locked...no creep. Press the gas when green, brakes released automatically. No transmission creep or need to keep foot on the brake or shift to neutral.
Several decades ago I thought it was just a matter of time before that would be standard on all auto trannies, but have never seen it again. The LS wouldn't happen to have that, would it? (Curiosity killed the cat; satisfaction brought it back to life.)
So apologies to all of you LS owners for not recognizing its Jag-ness earlier, though I was aware it wasn't a Panther, and probably not a BOF before I got here.
Is the consensus among LS owners that it is a well-executed Jag or not? just curious...some of those FoMoCo era Jags looked like badge-engineered midsize Fords, though I really don't know about their mechanical nature, as the styling never appealed to me.
Oh. I totally missed that. LOL. That is still there and should be good. There was water in the well when I jumped the beast this afternoon, so I'll double check that it is good. I'll send that one off to you for shipping as well.
The bolt and wing nut (whatever it is called) are pretty rusty at the point where they sit when installed. The bottom might be a bit rusty too. I might not have the large washer piece that goes under the nut too, I don't recall seeing it. Still interested? I can upload a pic too, if needed.
