Rear UCA inner bushing removal...
shagdrum
KS
any trick to getting the metal sleeve out? Or can you simply press the new bushings out of the new metal sleeve then press them in to the old sleeve on the control arm?
I have the bushings from super coupe performance.
burn the metal sleeve out?! The old bushings press right out of the metal sleeve...
You have to carefully support the stamped control arm to prevent bending the piss out of it, and use a press.
+1
If you don't have a press find a local shop you trust to press them out for you.
