rear passenger side shock or strut banging
newguy
chicago
hi guys,,is there some kinda bushing on top of the shock under the sensor,my rear passenger side shock sounds like it is banging or bottoming out everytime I hit a bump really sounds and feels bad and my friend at the parts store says there is no replacement parts showing for that shock on his computer only a 500.00 kit to replace it all,and it it hard to remove I have never taken one out
do a search you will find alot on this
just by 96-67 T-bird shocks and burn out the old bushings in the shock
mount
This on a 93? If so, that thing isn't a sensor on top of the shock, its a motor for adjusting the shock between soft and firm. (i think they did away with this on later models due to a better shock design)
Probably the rear mount rubber bushing is toast. You can burn out the bushings and order a set of Monroe Sensatracs for a 96' T Bird from somewhere like www.rockauto.com
Or, you could enquire with Max at Five Star Ford for new mounts...
Or, you could do as i did and get solid type mounts off E Bay.
Many cheap and easy options whatever you decide. Do a search for more shock info and replacement procedures. (its a pretty straight forward job)
The mount for that is a f3ly-18197-a list is 37.98 ea and LVC is 27.35 plus frt. If you need new bolts and washers a kit for each side is a f8lz-18197-aa list is $55.00 and LVC is 39.60 ea plus frt.
Max
I really can not recommend OEM in this case. I purchased OEM and they are already shot. They are "liquid" filled like the engine mounts and break down really bad.
I purchased solids, but......
