93mkviii
Alright I know there are probably a lot answers already to my questions but I rather get new opinions and it's easier if I post all the questions I have here. My mark viii's rear end has always been very unstable. So first I'm most likely gonna get a 1 1/4 sway bar from supercoupeperformance. So the other day boom, all the sudden my rear end is dropping and it gets fully slammed in less than 3 hours of standing. I can't hear any leaks when I first get out of the car so could it be a solenoid since it was fine one day and then the next day it's dropping. More on... the rear right clucks very bad over bumps but I can't recreate it while it's standing. It's like metal hitting metal clunk... what can cause this? Also when going over bumps the rear end shakes side to side( you can feel the car shifting left and right) usually very bad when going over a bump only on the right side but when going over a bump only on the left side it's normal so it must be an issue with the right side. On highway speed it shifts also, you can feel the car shift left right left right when going in a straight line... After having all these issue i've decide on just redoing the rear end once an for all and what would you guys recommend. Sorry for the long post and i know it's alot of questions but i thought it would be easier just having it all in one post. What should I do? I want to put in everything like a rear brace(IRS), sway bar, rear subframe bushings and other bushings, new bags and solenoids but i don't have the money for everything. I changed the shock absorbers about 3 months ago. What would you guys do? What can be causing the shifting issue and clucking and what can be causing the leak? Thanks again guys.
