BatMobile
Hey Guys,
I really need some input on this one. I've got a couple problems and I need some help figuring them out. I recently changed my pcv valve, pcv hose, valve cover seals and ignition coils. Aside from the bolts breaking that I mentioned before, it went smoothly. Okay, when I started the car back up, I get this loud, metallic clanking sound. It almost sounds like something fell down the manifold but I really can't tell. I'm also wondering if the valve cover with broken bolt is too loose. I could never get the broken part of the bolt out of the hole since the rethreading bit I used also broke off inside the broken bolt. I applied the gasket sealant and replaced the remaining bolts. Finally, the car comes up with a "P0193 Fuel Rail Pressure Sensor Circuit High Input" code when it was cranked up. I'm not sure the meaning of this and if it's related to the clanking I hear.
Does anyone have any suggestions or input I could really use it here.
