Ray-switch not venting in high humidity weather
Stangman
Project car a.d.d.
Sardinia, OH
Replaced my drivers side air strut, and a bunch of other bushings at the same time, and wanted to test the ray switch for giggles, but the car wouldn't drop. And now that I think about, it also wouldn't reset the compressor when I first started the car... anyone got any ideas? Im going to check my wiring connections tonight.
I don't know enough about the vents and solenoids, etc to know where to look first
I know I probably have 2 different issues going on here. Any input appreciated
It was on... that's what I couldn't understand. I had just used the switch about a week ago to reset the compressor
Does the car vent at all?
If you turn off the ray switch does it act normal..drop at speed...go to curb height when you close the door?
If no I would wonder if the vent solenoid in the compressor is stuck "common problem"
If you wired in the switch, and it worked I doubt it would be the switch.
