Quick Question..
96_Lincoln_LSC
Bristol
Will cobra "C" heads and upper and lower intake manifold just bolt up?
since I got sideswiped, I'll be getting a check somewhere in the range of 2K maybe more if the guy is nice... will fix small body issues and spend the rest on mods..
Is this a direct bolt on? IMRC's should be deleted, or modified to work with said setup? hood clearance an issue if I go this route?
Thanks
I believe it will work, if you use like the 01ish N/A cobra intake manifold. It kind of looks like a 2nd gen mark intake.
Will the complete assembly from a 99 cobra work?
I see a link on Ebay for currently 99.00
