96_Lincoln_LSC
Will cobra "C" heads and upper and lower intake manifold just bolt up?
since I got sideswiped, I'll be getting a check somewhere in the range of 2K maybe more if the guy is nice... will fix small body issues and spend the rest on mods..
Is this a direct bolt on? IMRC's should be deleted, or modified to work with said setup? hood clearance an issue if I go this route?
Thanks
Thanks
