defflepp1
so i've got a couple more question that i would like answers to that are not related to the suspension.
when i adjust the passenger side mirror, the up buttons moves it in and the right button moves it out, down and left don't do anything. what could be causing this?
i've got the 10 disc CD changer in the trunk but when ever i play a CD and go over a bump it skips. i'm not stupid or anything i know that shock will cause a CD to skip but its not only big bumps that cause it, is it just because its so old that a little bump will cause it to skip, or is it that like the lense is dirty or something?
is it normal for the sunroof to go back almost all the way the stop with about 3 inches left and then have to push the button again to have it go back that 3 inches?
when i push down on the brake pedal it slows down but i have like 1/4 inch of play in the pedal where its still braking but the lights will go off, whats up with that?
when i just press the windshield washer button there is no fluid coming out but the wipers wipe, if i move it a little bit up or down then only the passenger side sprays, whats up with that?
thanks again for any advice to these problem
