The car surges under low acceleration. I thought it might be an ignition problem, so I replaced the coils. I was wrong, it's a fuel problem. I just pulled these codes, what do I fix?
543: Fuel pump (FP) circuit open connection - Electronci Control Assembly (ECA) to battery.
524: low speed fuel pump- open circuit failure between battery and Electronic control Assembly (ECA).
175: Heated Exhaust Gas Oxygen (HEGO) sensor- voltage signal not switching (bank #2)
176: Heated Exhaust Gas Oxygen (HEGO) sensor- voltage signal indicates "lean" (Bank #2)
136: Heated Exhaust Gas Oxygen Sensor- voltage signal not switching during Engine Run Self-Test. Indicates "lean" (Bank #2)
_________________
Is the passenger side bank #2?
Does this mean I need to replace that O2 sensor?
And what do I need to do about the fuel pump circuit? I'm not familiar with that.
_________________
