lls05
HOW DO I REPLACE MY PUUDLE LAMP BULB IN THE MIRRORS ON A 2005 LINCOLN LS? THEY LOOK LIKE THEY ARE A SOLID POD AND CANT CHANGE THE BULB TO A LED LIGHT.
DAN
DUPD120@YAHOO.COM
DAN
DUPD120@YAHOO.COM
so the clear plastic piece comes off of the pod right? do you know what the number is for the buld replacement? thanks for your helpUnhook the puddle lamp from the mirror. I just used two sets of pliers, grabbed the bottom and the top part's lip and pulled, be careful so you dont break it. It comes off, you can also try and wedge a flat head in there to not break anything. I just used super glue so put it back together cause I didn't have anything else but you can use sealant or some epoxy. Oh and if you're getting some led bulb replacement. Those run a little fatter from the ends than the stock ones so you'll have to open up to two clips that hold the bulb a little so if fits. Just widen it up a bit and it'll fit, just make sure you have the polarity on the right side before you seal them up.
