Plug Gap
new plugs should be checked for proper gap before you put them in even if they are to spec when they leave the factory
The OEM (or any factory gapped plugs) may leave the factory with the correct Gap, but more than once I've ran into instances where the gap was far less than "advertised". I only suspect that loading, shipping and unloading the boxes that contain these plugs aren't exactly treated with the utmost of care.
Cliff notes: It's always a good idea to check gaps on pregapped plugs.
00ls-sport said:
you checking yours, or did you buy new ones? oem usually come pregapped correctly.
Naw Jon, new ones; the only I bought off you like 2 months ago...finally changing them...
Naw Jon, new ones; the only I bought off you like 2 months ago...finally changing them...# 8 cylinder is kicking my ass.....can't get the :q:q:q:qer out
bout time!!! any update one the fender or washer bottle stuff?
