96mark8
Hi all,
i am brand new to painting car's so bare with me plz. i just want to make sure i do this right. so a couple months ago i was all ready to paint my car i spent a week filling in holes sanding, prepping etc... but right when i was ready to paint my air compressor took a crap on me i did not have the money to buy a new compressor and my car was all ready sanded down. i know it would be awhile before i get a new compressor so i decided to prime it all with some spay cans as a temp fix.
So here is my plan tell me what you guys think. first i want to try to sand as much or the old primer off as i can. Then i want to hit the car with a coat of the new primer (first link), sand that with 200grit and then hit it with another layer of primer.This is wear i am not sure should i just sand the second coat with 200grit or should i wet sand it? after that should i just hit it with 3 layers of my base coat(second link) and what grit should i use in between coats? after those 3 coats do i just wet sand, buff and i am done? this is a single stage paint so it does not need a clear coat right?
http://www.eastwood.com/ew-2k-urethane-primer-gray-gallon-4-1.html
http://www.eastwood.com/paints/automotive-refinishing/ew-royal-blue-and-activator-kit.html
and will one of these be enough to paint the whole car?
 i did not have the money to buy a new compressor and my car was all ready sanded down. i know it would be awhile before i get a new compressor so i decided to prime it all with some spay cans as a temp fix.So here is my plan tell me what you guys think. first i want to try to sand as much or the old primer off as i can. Then i want to hit the car with a coat of the new primer (first link), sand that with 200grit and then hit it with another layer of primer.This is wear i am not sure should i just sand the second coat with 200grit or should i wet sand it? after that should i just hit it with 3 layers of my base coat(second link) and what grit should i use in between coats? after those 3 coats do i just wet sand, buff and i am done? this is a single stage paint so it does not need a clear coat right?
