Justin00LS
On the plus side, I replaced the fuel pump as preventative maintenance and that went very well. On the minus side, I saw some other things going on while I was under the carpet.
That's one of them there northern cars!![]()
She's spent her entire life in Kentucky, if that's considered northern. lol
JDM Stage 3 weight reduction rust
Only real option is to cut and grind all the metal back till you see no more rust, and weld in a new piece.
They do make an acidic metal prep solution that eats the rust up and gives you something you can paint. Not sure how well it'd work there. I used it once where battery acid had eaten up the battery tray and some of the fender below it. They should be able to tell you what it is at a body shop supply store.
