My tire is flat and I need help getting it off. All lugnuts are off, now what magical tool do I need:runaway: . Oh, by the way hi :waving: long time lurker first time poster.
I am hopeing that the car is safely on jacks and the tire is free to move in the air. That being so, I bet your wheel is "frozen/rusted" onto the hub and a good whack with a large tire iron or BFH on the rubber should help get it off.
I had a wheel do that to me before back in Ohio. Road salt and water led to electrolosis and the wheel had gotten corroded on the hub.
a jack? Or is the wheel stuck on? If it is a front, you can use your power steering and a 2x4 to break it loose. Put the 2x4 between the wheel and a suspension peice and turn the steering wheel. Or you can use a 2x4 and place it against the edge of the wheel and hit it with a hammer. Mine were stuck on, it just takes a little force.
Ok I just sat down next to the tire (already on jacks) leaned back kicked one side of rubber with my boot, very hard, then the other. It took four or five kicks but it finally broke free. Also a bead of corrosion came off in a ring flatter than paper, like the wheel had chemically welded itself to the hub. Ok so note to self by the way, rotors look dangerous
