mikemark8
Headed out today and while at a light i noticed a little smoke rising up next to the car (96 mark)-I pulled it over and checked under the hood, saw that there was a little antifreeze around the surge tank (just topped it off yesterday and figured I overfilled it). I looked underneath, and it was pouring oil. I shut it down and had it towed home, where I discovered that the oil pressure switch was leaking, big time. Went to the Ford dealer and got as new one, installed it and poured in 4 quarts. I sat for about 2 hours and lost a lot while sitting, started it up and it sounds ok-no tapping, just sounds normal-but the idiot light stays on. I did check to see that the new sensor was hooked up, and drove it-feels perfectly normal, but the light is now on all the time. Defective sender? Any guesses?
