Oil impregnated Bronze IRS Bushings.
94m5
Dmaup's Daddy
Colorado Springs, CO
Hey guys.
I've got a few linear feet of Bronze bushing stock on the way for my IRS build up. I am machining them on a CNC lathe and precision will be top notch. I am only making enough for me, but if someone had a performance tuned suspension in mind I could run a few more off.
These are NOT gonna be for a person with comfort as a priority, they will be very stiff, but deflection under high loads will be nil. Anyone interested in a set?
How will handling be affected? are you talking about the bushing thats on top of the knuckle? Confort isnt really an issue for me, since I can adjust the confort by PSI.
Hes talking about the front diff mount.
I believe Steeda or one of those suspension specialty places already makes them in aluminum.
The knuckles would be cool but I am not going through the rest of the suspension to go with it right now and to ear into it just for these wouldn't be worth the time it would take me.
Be carefull with the front diff mount. Not to common but people have broken the ears off with a good amount of power and hard launches. I see and Aluminator/Tremec in your sig. MM has an aluminum front and read dif mount for the Cobra. I don't know how different the Cobra rear mount is to know if you can make it work.
Well at least there is interest.
I'll get some drawings and renderings done to give you guys an idea as to what they look like.
Mike
