keatonsdad
When I mash the gas the message center tells me how long the auto lamp delay is. Is this the start of something bigger?
My guess is that the dial isn't as tight as it used to be and is moving due to your speed racer type antics.
BINGO! Same here, I get it at times when I press the O/D or when i lower a window. It hasn't happened in the last couple months though. Only happens once in a blue moon.
Seems to be pretty common. I get that message randomly all the time. I figured it's the switch, because if I turn it up and down real fast a few times it stops for a while. The potentiometer is likely dirty.
