Shredicus
So I recently bought a bluetooth OBDII reader and hooked it up to the app "Torque". It popped up a few errors with the o2 sensors. Here's the report:
So basically it looks like I have 2 failed sensors on Bank 1 Sensor 3 and Bank 2 Sensor 3. I've noticed I get pretty poor gas mileage, it seems to "bog down" a bit and I have to give it a lot of gas for it to accelerate smoothly, and occasionally I'll get a "rotten egg" smell in the cabin on hard acceleration. I'm getting no DTC codes though. The coils and plugs were all changed out about 3k miles ago for Visteons/NGK Plat and VCGs were done, but prior to that I was getting misfires on at least 2 cylinders, although I dont remember which banks they were on.
Basically I'm wondering if it'll be worthwhile to change out these O2 sensors or if this is a sign of the cat(s) being toast. Any input?
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 7.99527V Min: 0V
Test result value: 0.44994V
PASS
MID:$01 TID:$80
Max: 7.99527V Min: 0.49996V
Test result value: 0.8213V
PASS
MID:$01 TID:$81
Max: 3A Min: 0.465A
Test result value: 1.068A
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$81
Max: 3A Min: 0.27A
Test result value: 0.529A
PASS
MID:$03 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 3
PASS
MID:$03 TID:$81
Max: 3A Min: 0.22A
Test result value: 0A
FAIL
MID:$05 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$80
Test result value: 0.83753V
PASS
MID:$05 TID:$81
Max: 3A Min: 0.465A
Test result value: 1.039A
PASS
MID:$06 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$81
Max: 3A Min: 0.27A
Test result value: 0.521A
PASS
MID:$07 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 3
PASS
MID:$07 TID:$81
Max: 3A Min: 0.22A
FAIL
MID:$21 TID:$80
- Catalyst Monitor Bank 1
Max: 0.64843Ratio Min: 0Ratio
Test result value: 0.10156Ratio
PASS
MID:$22 TID:$80
- Catalyst Monitor Bank 2
Test result value: 0.10937Ratio
PASS
