420ss
i was thinking, couldn't i put, in my trunk, a bigger compressor connected through a regulator to a 5 gallon air tank with 4 1/2in. lines running off it, then running a line to each stock air bag the same way other members have done when they convert their stock system to a fast bagged system. Pretty much long story short what i was thinking was installing a completely separate 1/2in. line fed fast bag set up all while leaving the stock system hooked up and fully functional. then since the new system would have it's own fill and dump valves all controlled by switches in the passenger cabin, all i would do is re locate the air ride on/off switch that is in the trunk to the same switch panel that would be in the passenger compartment. Then i could turn off the stock system and use my fast bagged system, then when i was done i would turn the stock system back on and go back to my set ride height and computer controlled features that we all love about our marks. now i now that this sounds like a lot of work and more money then i would need to spend in order to gain manual control of my stock system, and i know that i could redo the 1/4in. lines with 1/2in. to have it a fast bag system, but doing it this way i could slowly build this system up without having my car taken apart for extended periods of time, and i would wait on tapping into the stock bags, i would tap into them last once the second system was complete and fully operational, and this wouldn't strain my charging system cause the stock system would be turned off when i would be using the fast bag system. this is just a theory so some input for other members would be greatly appreciated.
