Noob question !!!!!!!!!!
1bad4.6l
wyandotte
Ok I am doing the tps on another mark and was wondering if I pull the throttle body will I destroy the gasket? it's never been off the car before. I am guessing that I will. please help and TIA.
If you're careful it won't. You can use any gasket paper though to make one if you do break it - the actual gasket is difficult to find.
True, if you're careful but you have a 50/50 chance and unless you live in Egypt, close to the pyramids, the gasket should be easy to find. I have bought 4 and they have always been in stock. Call ahead and make sure one is at your local parts store.
If it sticks to the TB, don't touch it because it will break, meaning, don't try to lift up on the edges of it.
Was able to locate one at an Autoparts dealer here in Philly. was about 2 bucks IIRC.. they had it in the hub store and had more then 1 in stock.. I was shocked
if you need one I can help you out here .
Bill
Always seems to be a 50/50 chance with ford paper gaskets as mentioned above... 50% of the gasket on one part, and 50% of the gasket stuck on the other part! :lol:
I've popped some explorer 5.0 motors apart and never hurt a single gasket... dunno how in the world I managed that either...
