CobraConti
My parents own a 95 Continental that will not start. I said need help quick because they are calling a tow truck tommorrow to take it to a dealer and i want to try to figure this out before they get reamed by the dealer. This is a weird problem. The car was running fine up until about a week ago.
When you try to crank the car it acts like it doesn't have any gas but it does, it has almost half a tank. It is not a power problem because radio and everything works and the car will turnover forever if you keep cranking it so its definitely not a battery problem. This all started when my mom cranked the car last week and drove about 100 feet out of the driveway and the car just cut off. They tried repeatedly cranking it with no avail. They waited about an hour later and came back and it started up instantly. They drove it back into the driveway where it will not start at all anymore. I tried it today, the gas guage had 1/4 a tank, and on the first attempt the car actually cranked and ran for about 1 second then cut off. I tried it about 4 times after that and it never cranked, just turnovered repeatedly. Basically, its like the engine just isn't firing. So i thought maybe the gas guage was broken so i went and got some gas and filled it up to about 1/2 a tank. The guage went up, so its not broken. Cranked again repeatedly with no avail. The car is having air suspension issues but i don't see how that affects this. The car has had the "Check Engine" light on for about a year but the car has run perfect for that last year.
Any help is appreciated. I haven't popped the hood yet as it was dark when i got home tonight from out of town. Tommorrow will pop the hood and look around. If all this is because a spark plug wire has come off...............ill be pissed and happy! *owned*
