no heat!
mark82nv
biotechnical engineer
aurelia
ok i know this is going to get someone to say search the threads or that is a stupid question so im sorry in advance , i have no fan at all now if im not mistaken the blend door just controls the amount of heat coming out not the fan blowing right?
Flip your glove box down and wiggle the top plug I belive on the controller thingy. The plug gets loose. Mine did it when I bought my car and even though I replaced the $45 harness it started doing this year again.
no luck with any of this tried all fuses wiggled all wires , still no fan !this fan is easy to change isnt it?
Run the EATC self test on the unit by pressing off and floor at the same time, then press automatic. If you get any codes, post them here. If nothing, check the vacuum harness on the back of the unit.
went out todaY and the fan works now went for a drive and now i got a huge miss its 30 below and the miss is at different times sometimes off startand sometimes during acceleration so i wonder if i got some water in fuel?
