Hi!
I've been reading about this issue on the site , very helpful info.
I need a tip of how to handle this situation. thank you!!
2001 LS v8 @110,000 miles-
p0775 code.
I was planning to maintenance the suspention but it had to wait.:frown:
The transmision was shifting right , sometimes a little strange from 1rst to 2nd, the upper shifting was fine and smooth.
Today i note that it develop a high rpm almost hitting the engine red-line without shifting to 2nd, it does not shift unless i let up on the accelerator.
it shifts fine and smooth if you run slow.
looks like i loose 2nds if i move the lever.
Some minutes after driving ,the warning " check transmision" appears on the dash screen followed by an "E" where the shift lever indicator is.
CEL code " p0775"
I read this post about the 5r55 repair also the Andy's fix "servo bore" and Sleeve from sonax.
the symptoms point out to "servo bore" issue.
What do you think about ??
thank you!
p0775 code.
CEL code " p0775"
thank you!
