Nitrous
SilverLS
Winter Park (near Orlando)
Hey everyone Just wanted to post a quick question I work for a Nitrous Company and I make and sell nitrous kits (wet kits ) and just wanted to see if anyone is wanting a kit i can see them pretty cheap and know everything about them
check out the website www.ny-trex.com if your interested email me or pm me
Silverls@earthlink.net
Thanks again
Dustin :L
Not if you do it right
lexdiamondz10304 said:
I have a v-6 and would like to put NOS in it.., but does it hurt the engine in the long run?
Yes and NO If you try to exceed the limits of your motor and drive it hard everyday yes it will harm the engine in the long run but if you run a 75 wet shot with colder plugs (1 step closer ) and you use it smartly (not all day everyday from light to light and let it shift at red line in everygear ) it will last as long as a normal car if you have any more questions let me know
i had it on my s10 (4.3 v6) i ran about 45 or so bottle on it in a 6-9month period and i traded my truck in and got 11500 when book was only 9500 so i mean i did it right and safe and you couldnt even tell i had it on the truck
let me know if you have any question i can answer them
what are colder plugs?? and how much $$$ am I looking at?
Quick, the reason you couldn't find a colder plug for the LS is because there isn't one listed as a "Colder Plug for the LS" as there is for Mustangs, F-body's, ect. But, this doesn't mean there isn't a colder plug.... you just have to find it yourself. When i ran my turbo on the ls, i ran 1 range colder. Every spark plug company has its own way of oraganizing, and coding sparks plugs using a sequence of numbers and letters. I use Champion plugs, so if you look at the standard copper part number for the Champion plug for the LS It is an RC12YC or an RC12YC4. Next you have to bread down those numbers. The "R" means it is a resistor plug. The "C" is its shell style... a "C" shell type means a 5/8" hex with a 14mm thread dia. and a 3/4" reach. The 12 is your heat range number, usualy in incriments of 1. The "Y" and "C" are your electrode designs, in this case the "C" stands for copper electrode, and the "Y" is for a standard projection. The last number is a generic gap, this is done for ease of installation, so a 4 in this case means a .40 gap (the LS calls for a .44 gap).
Ok, so now take this number and move your heat range down one value and you would get an RC11YC.... now the confusing part here is that there is no 11 heat range in this series. Move one more to an RC10YC4 and you've got your plug. Now, remember that this is a standard copper plug.... so now you can cross reference it to a platinum, double platinum, ect..... A double platinum would be an RC10PYP4. I got this by changing the electrode design number to a PYP which is a double platinum.
BTW, this plug is for the 3.9. You 3.0 guys use an RS14YC6 this plug is still a 14mm thread but has a different reach with a taper and a different gap (.54 on the V6). So a step down for you guys would be an RS12YC.
ok listen ive been drinking. I just read that reply and damn near passed out. However it was a dead on balls answer. I learned something new today.
How much are you money are we talking about to NOS my carbed engine?(351W)
Not looking for much a 50 or 100 shot, I have hyperutectic pistons, does that give any advantage?
I do want my engine to last and I've been thinking about NOS for some time now, so I gues I'm just looking for a price and recommendations
so what are these cold spark plugs for?
ok the colder plug is to help with detination wich is when your plug pre-ignites the fuel in the piston camber (the colder plug doesnt burn as hot and this keeps the heat down and limits the detination also look for a plug with a smaller strap (the finger looking thing on top of the plug) this will also cut back on your chances for having detination ) if you still have more questions let me know.
I curious how much a set up like this would cost. Any rough ideas?
the NX system I ran was $580 for the kit
+ purge valve kit
+ remote bottle opener
+ bottle warmer
+ fuel pressure guage
+ NOS pressure guage
$1,100 (I think)
thamarkman How much are you money are we talking about to NOS my carbed engine?(351W)
ok first off i need to ask you some more info
What are you looking for as far as a kit goes
Basic, or basic with purge and fuel pressure safety switch and bottle gauge, or you looking for something that looks great and has everything??? let me know i have something called a triple threat and it has all three valves in one and its super clean and looks hot let me know check out the pics in my links to my car domain its on my car already and i can set you up with a plate set up also and cheapper than 800 for the mack daddy kit
Check out the site and let me know wich one you want and i will get you LINCOLN owners price (the i net prices are set higher I can sell them cheaper)
just check it out and let me know
SilverLS----
Your car is sweet man, unbelievable really.
From your site it looks like I'm looking for a Ny-Trex V8 Spray Plate Nitrous Kit, am I correct?
thamarkman said:
SilverLS----
OK cool thanks for looking at my car im going to update the pics soon ive got two bottles now and im painting them different again.
Ok if you want that kit i can i can sell it for $525
