Newbie
MercuryLs
Lawrence
My name is "Mo", I'm new to the site. These are my rides...
(1) 1993 Lincoln Mark VIII
Mods:
-1996 Mark VIII engine (swapped out all the sensors & '93 Intake manifold)
-No EGR
-Underdrive pulley kit
-Custom made Intake
-AODE tranny w/ TransGo Shift Kit
-RoadRunner 2500stall converter
Mods to do this Month:
-3.73 rear gear
-Dual Exhaust w/ no cats
-MSD wires w/ Iredium plugs
-Dynotune Chip
(2) 1994 Mercury Grand Marquis GS "GT"
Mods:
-'98 Mustang GT heads 80,000 miles on them
-Dual Exhaust w/ NO CATS
-Flowmaster Delta flow 40 series
-Gutted air box w/ ram air
-K+N airfilter
-Throttle body spacer
-MAC underdrive pulley kit*
-Ported Intake elbow*
-Bosch +4 Plugs + Bosch o2 sensors
-Accel Plug wires
-3.55 rear gear
-Trans Go shift kit
-Eliminated EGR
-Brand new Ford Motorsport 19lb injectors
-3 inch tach
-Car ran a 15.4@88mph quarter mile w/ spinning a bit off the line and with out the mods w/ the * by them.
-Last July a Coolant hose broke on the highway. Long story short, the engine blew and now it sits in the barn till I decide what to do w/ it.
(3) 1994 Mercury Grand Marquis LS "COBRA"
ENGINE MODS:
-'98 Mustang GT Block
-DSS Pro-lite Pistons and Forged Rods
-Cobra Crank
-Ported and Polished PI heads
-PI Intake
-Ported Intake Plentum
-Comp Modular EX278AH Camshafts - .550"/.550" 278/282 242/246
113°
-Lincoln Mark VIII 80mm MAF
-Lincoln Mark VIII EDIS ignition module + Blaster Packs
-24lb Injectors
-255lpm fuel pump
-Helix Throttle Body spacer
-MAC Pulley Kit
-Cobra High output oil pump
-Eliminated EGR
-Accel Wires
-Bosch Platinum +4 plugs
-Bosch o2 sennsors
-Gutted AirBox w/ Cold air
-K+N air filter w/ tornado air thingy
-Dual Exhaust w/ NO CATS + Flowmaster 40 series Mufflers
-Reinhart Custom Chip
TRANS MODS:
AODE Trans w/
-2400 Stall Converter
-Trans Go Shift Kit
-4.10 Rear Gear w/ posi
Well, the oil pump went out and fried my Cam bearings. Being that it is an OHC engine the cam bearings are machined to the head. Sooo I'm going a new direction w/ the cobra and decided to go w/ my built 5.4. When I'm done w/ the "Cobra5.4" Project this is what it will be....
-2001 Lightning 5.4liter 330cid SOHC
-Forged H-Beam Rods
-Forged crank
-Patriot Stage III Heads
-PI Intake
113°
-90mm MAF
-MSD DIS-4 Ignition and MSD Blaster packs
-KenneBell Boost-a-Pump
-KenneBell Boost-a-Spark
-24lb Injectors
-255lpm fuel pump
-MAC Pulley Kit
-Eliminated EGR
-Accel Wires
-NGK Iredium Plugs
-Bosch o2 sennsors
FUTURE PLANS
-electric water pump
-Procharger F2M
-F.A.S.T. system
-Aeromotive A1000 fuel pump
-Long tube headers w/ 3" exhaust
-'98 Grand Marquis front clip
-Paint car Black
-17" Cobra R rims
(4) 1983 Ford F350 "Mo's TOW TRUCK"
-6.9 liter 420cid V8 DIESEL
-Dually w/ 4.10 rear gear
-T19 4-speed manual tranny
-New Injection Pump (turned up a bit)
-K&N Intake
-Cut-out exhaust
Well that's a little about my vehicles. What do you guys think?
Thanks.
Hey where can I find a 180* thermostat for my 1993 Mark VIII? What would the part number be?
Check out Summit or something...
Or ford racing I thinks?
I dunno I don't own one of these yet...
Tooo many BMW's right now
When I get back to the states thought... :shifty:
Mwuahahhahahahah
You can get a 180 degree thermostat from Motorcraft... Don't get anything less than 4.10 gears for the Mark VIII!
If there is an Oreilly's auto parts near you they should have what you need, that is where i go for parts!!!
Ford Dearlership, Advanced Auto, Autozone, & Oreill's- Said they do not have it.
DOES ANYONE KNOW THE PART NUMBER?????????
