05 LS8
also were did you get the replica wheels from
http://cgi.ebay.com/ebaymotors/18-V...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
T-Money, those look real sharp. Just slap on some LSE tails and you are set.
and will the 19 fit with my car lowered
ok thanks t money i do have the eibachs were can i find the company to do the head lights
19" Volvo XC90 replicas, that are PVD (permachrome) plated.
PVD is best for midwest weather.. 5 year warranty, they are not
suppose to pit or peel.
PVD is the finish I got on my Jaguar wheels too - I'm hoping it holds up to New England winters too!
Thanks,
and i think they will do well over the winter..
I personally do not drive my ls when there is snow on the ground.. my dad has an old f150, i normally drive that until the snow is completely melted.. and this year i plan on buying an Aviator knock on wood, hopefully i dont run into alot of the mechanical issues they have although the ls is prone to that sort of thing too.. but i will drive the aviator over winter.. but i may want to pull the ls out of storage late winter when it starts to get nice and there may still be salt on the roads so i figured better safe then sorry.. ++ the pvd in my case was cheaper then regular chrome because of shipping..
If anyone ever sees a 2003 Lincoln Aviator Kitty Hawy Ed. with less then 80k and has navigation get at me.. they are had as hell to find.. oh and preferably a 1 owner .. Im not picky i just have standards lol
the wheels i actually found on amazon back in the day, and got free shipping.. the 18" ones on ebay are from the same usarim though, and if there isnt a 19 avaliable at the moment im sure they will have a set up for grabs soon.. also might want to email them.. and good luck finding oem wheels for 695.. i was originally considering jag wheels and unless your lucky youll spend at least double that,,..
and yes they will fit depending on what springs you used, and what tires you get.. but the offset is higher then stock so you should be able to make it work.. youll just have to get the right tire size.. i know eibachs work no problem and i have 245/40/19
Naw you won't rub. Your tires are slightly taller than mine and the JAG setup drops the car less than Eibach I am pretty sure.
I would go with Eibachs if I were you. Then buy shocks separately.
