Neeed Radiator and Rack & Pinion 95 Mark
MsM8tress
Right here ;)
Soon! Like NOW lol if you are close to Columbus OH Mechanic just told me that I need a new rack n pinion... power steering fluid just pours right out... man that sucks!!!! guess the radiator has a leak also....
any way to fix a r&p, ya gotta replace the whole thing? can i replace the radiator?
I wouldn't trust buying a used radiator..just buy a new one at your local parts store for 140 ish..that's how much mine was..and if you don't want to deal with leaky trans line fitings get an 03/04 cobra radiator with no built in trans cooler and put in a small remote trans cooler..I may do this as mine leak a little..
yeah - I thought about the junk yard radiator ... not a good idea I determined.
Got a good deal on a rack from Car Quest around 80.00 and inner rods are attached. Good deal custom97 - did you install it?
Thanks G, but SnH would get pricey and time is of the essence...
Thanks Hotties ;)
Guy did rack and bushings calls me up and says she steers like its a manual! He said rack may not be good. Is there something he didn't do or did do and shouldn't have??? I supplied the rack so if it is bad, I'm screwed outta what... hours of labor (is that about how long it takes to change one in a shop)?
Radiator Classic
http://stores.ebay.com/RadiatorClassic?_trksid=p4340.l2563
Fof you:
http://www.ebay.com/itm/Brand-New-1...e:Lincoln|Model:Mark+VIII&hash=item5d32342902
Thanks, Alexsander.
Lincoln MARK VIII Collector’s Edition #979
Thanks Hottie - but I got em already ;) problem now is rack is so stiff that drives like a manual .... got me wonderin if he checked the power steering pump... he should have... dang....\
Thanks again - smooches
