So I Had the Anti-lock light come on and traction control went off-line, and i figured it was because of aging brake's so I ended up replacing the rear brake calipers and brake pads, then after bleeding the system, I went out to test drive but after a couple minutes of driving the anti-lock light came back on and trac, off-line, is there a way to reset the abs/traction or did i miss something
Thanks!
Thanks!
