Need some advice on potential mods...
DieselDan
Orlando
I Hey guys, I just recently got together the funds to do some needed repairs on my car. I had held off until now because what I need to repair all requires the subframe to be dropped. As it stands I need to do the oil pan gasket and oil filter adapter gasket. While everything is apart I am going to replace all the strut rod bushings with FoMoCo parts... I am ordering new tires tomorrow and the car will be aligned after all the repairs are done. I will have enough money to do one moderate mod while I am at it that also requires the subframe to be down.
They are:
1) Front 1 1/4" addco sway bar with Energy Suspension bushings. The bar will be about $205 plus $16 for the bushings.
2) Cobra manifolds and steering column mods. Already have a set of manifolds for $80 and the column parts would be about $130 plus $100ish for exhaust work.
3) Save up and do it all at once.
While the car is apart I am installing a set of Turbo Chuck's stage 9 engine mounts, an Energy Suspension trans mount and also the flaming river steering joint.
I am looking for biggest bang for my buck. If I do the front sway bar, I would install the rear one in the next month or so. I think the car would sound badass though with the exhaust finished with no cats, gt500 X and the borla mufflers. I am torn, I can only do one mod at a time and the exhaust is at the top of my budget.
The manis are going to require exhaust work, so factor that cost in.
I'd do it all at once personally.
Mike
If you can wait do it all at once.
If you cant wait do the Cobra manifolds, if it was me I would spend the budget.
Get the exhaust done.
figure you have to drop the K member a little for both the manifold work and sway bar so you might as well do both at once. I have done the manifolds. Easiest thing would be to remove the Kmember completly since some of the bolts are a PIA to get at. Others may disagree.
What did you do with your EGR? My car is chopped so I am wondering if the EGR is already turned off in the tune. Last thing I want is a CEL.
