Some new developments. The problem continues, but I am now zeroing in on some other symptoms. When the shifting problem occurs, I can smell exhaust inside the passenger area and at times the AC compressor will stop running. It now seems that whatever is causing the trans to downshift is NOT the trans itself. Could clogged cats or something else related to the O2 sensors have anything to do with it? I have cut off my mufflers and extended the tailpipes back. Normally there is no exhaust smell inside the cabin, but when the shifting issue occurs, I notice a strong exhaust odor. The problem also seems to occur when the vehicle is not warmed up, about 1/2 way home on my 20 mile trip, it will start shifting perfectly. The last hint is that it NEVER happens on acceleration, only while cruising at a set speed of 50-65 mph. As long as I am in the gas fairly hard, it pulls strong without hesitation. Any other ideas?
