thanks for all the good advice. witch would you guys recommend replacing with air shocks or just converting to coil overs
I just went to coils.
The coil conversion kit for all four wheels was about the cost of one front OEM strut.
You can get the Arnott strutts for about 155 each, which makes that conversion just a little more expensive then the coils. However, in doing some research, I found that the average lifespan of the Arnotts was about 1 year.
Eddie at AA says that the Arnotts are made better nowadays, so it may be that older conversions used inferior struts, I don't know. For me, I needed some assurance that I wouldn't be spending another 500 bucks on the suspension for the next few years (which would change if the OEM struts get to be in short supply) so I went with coils.
Now, having said that, if I could have afforded the OEM struts, I would have gotten them. And having driven on the coils, I'll say that if you can afford the OEM struts, get them. The ride was noticably stiffer with the air, and not in a bad way. I find the coils to be softer, which I do not prefer. That said, the car still drives and handles well, just not like I am used to.
As soon as I can afford to redo my air system, I will.
