More LS Excitement
Lincoln LS
  1. Knuckles
    Knuckles LVC Member
    14
    4
    Jul 23, 2018
    Hunstville, AL
    2004 LS V8, 168K miles. Got in this morning, turned the key and nothing. Warning lights go out as usual with the key in start, but no crank and not so much as a click from a solenoid. Check the battery, up to full charge, terminals clean and tight. Tried starting again, same result (sign of insanity, I know) Turned on the headlights and tried to start, no crank and the lights did not dim. Apparently the signal to crank is not getting to the starter solenoid. Anyone have a wiring diagram showing the starter circuit? I expect I need to start looking for the lost voltage between the starter and the key switch.
    Oh, almost forgot...this afternoon I decided to try again in the hope it might start so I could get it out of the driveway so we could at least use the other vehicles. It cranked right up and I shut it off and tried several times again and it started each time. So now if you go somewhere you never know if you're going to get home..."do ya wanna gamble, well do ya?"
  2. Svets96
    Svets96 Dedicated LVC Member
    658
    86
    Jul 18, 2005
    North East Ohio
    Might also want to check a fuel pump driver module, and fuel pump and circuit. That also could be an additional thing to trouble shoot before paying for other parts.
    Hope this helps.... Others will also be chiming in shortly.
  3. Andrizzle
    Andrizzle Dedicated LVC Member
    5,080
    74
    Mar 11, 2009
    Oklahoma
    Not sure if it is possible to turn off the LS without the car in Park, but make sure it is fully in Park. Move the shifter more aggressively into Park next time it won't start and see if that was it.
  4. joegr
    joegr Dedicated LVC Member
    20,288
    1,613
    Dec 10, 2005
    Gulfport
    Yes, it's possible to turn the key off in any gear position. Starter will only engage in the park and neutral positions. Might try neutral next time...
    No, fuel pump or REM wouldn't prevent the starter from engaging.
    Next time this happens, please look at the PATS light and see what it is doing. If it is flashing rapidly, then wait (leave the key in the on position) until it slows down. It will then flash out a two digit code a few times. Report back with that code. (The PATS light is the little red light at the center of the dash at the base of the windshield.)
    • Like Like x 1
    • Agree Agree x 1
    • JaredI
      JaredI LVC Member
      44
      6
      Aug 16, 2016
      Bardstown
      Fought with this issue a while myself. Swap the starter motor relay with a known good and see what happens.
    • clubairth
      clubairth Active LVC Member
      142
      4
      Apr 22, 2005
      home
      Follow Joegr first and report back what the PATS light is doing. Your symptoms point directly to that.
      • Like Like x 1
      • milehighmikey
        milehighmikey Dedicated LVC Member
        806
        56
        Apr 2, 2007
        Nashua
        Do you have multiple keys? My friend's Taurus did this and it was a bad key that had been working! Changed to her spare key and it fired right up.
      • Knuckles
        Knuckles LVC Member
        14
        4
        Jul 23, 2018
        Hunstville, AL
        Well, the LS decided to leave me stranded at work, on the coldest night yet. Granted it was only 49, but it was 75 when I left for work this morning.
        Anyway, turn the key and I hear the fuel pump (I think) and that's it. The dash lights come on with the key in "run" and go out when I turn it to start. Now the PATS light - when I turn the key to start it comes on steady. If I turn the key to start and hold it even though there is no life in the start circuit (my assumption) the PATS light goes out. Holding the key in the start position for a full minute, dash lights are out, PATS light is out. The headlights come on because it is dark and they don't dim when I turn the key to start. No blinking from the PATS light.
        I hope there is a clue in there somewhere. In the old days I'd be looking for a relay not energizing the starter solenoid. What do you guys think.
      • milehighmikey
        806
        56
        Apr 2, 2007
        Nashua
        Did you ever try an alternate key?
      • Knuckles
        Knuckles LVC Member
        14
        4
        Jul 23, 2018
        Hunstville, AL
        Well, the LS came home on the hook Friday morning. I tried starting it with both my key and the wife's key and no joy. Same reaction. When it failed to start Thursday night I pulled the starter relay #15 in the underhood fuse box and re-inserted it but no luck. So this morning I tried to start it again and got the same result. I then swapped the #14 and #15 (the part number molded on top is the same for both) relays and it started right up!? So am I looking at just dirty contacts or have I just put a problematic relay in the PCM circuit?
        This morning I'm going to pull each relay and clean all contacts. I'm also going to swap the relays back and see if I can re-create the problem. I guess I'm just confused.
        • Like Like x 1
        • joegr
          20,288
          1,613
          Dec 10, 2005
          Gulfport
          I would replace the relay. BTW, your description indicated that PATS was working correctly, and that the PCM was getting power. For the most part, that leaves the starter relay, the starter, one big fuse, and a little bit of cabling. I would have suggested swapping the starter relay out first. I know, you're asking where was I. I was home with no power and no internet after being hit by Zeta. We just got both back.
          • Like Like x 1
          • Knuckles
            Knuckles LVC Member
            14
            4
            Jul 23, 2018
            Hunstville, AL
            Hey, thanks for your reply Joe. Sorry to hear that Zeta hit you, hope there wasn't too much damage to your home and area. You folks have had more than your share of serious weather this season!
            I swapped the relays back into their original position and the car still starts just fine. These relays run about $16 so I'm going to replace it anyway. I thought that a bad or dirty contact might have been the original problem which is why I tried removing it and re-inserting it in the parking lot.
            • Like Like x 1
            • Knuckles
              Knuckles LVC Member
              14
              4
              Jul 23, 2018
              Hunstville, AL
              Replaced the starter relay and it worked for a couple of days. Then, same symptoms and stranded in a Walmart parking lot. Swapped relays with no joy. Called the wife and then tried again and it started! Called her back and drove home.
              I pulled the relay and looked at the five slots in the socket. Got out the trusty VOM and started poking. The slot at 12 o'clock, no voltage present. Slot at 3 o'clock appears to be a ground, at least is showed continuity when I tested between it and a ground on the block. Slot at 6 o'clock had 12V. Slot at 9 o'clock no voltage present . The fifth slot, in the center, no voltage or ground.
              I'm guessing that if I jump the 12 o'clock and 6 o'clock slots I'll probably energize the starter...but will I damage something like the PCM or some other electronics in the car?
            • milehighmikey
              806
              56
              Apr 2, 2007
              Nashua
              You should be fine, this is how a compression check is done. FWIW, this is also how you can permanently bypass PATS. Once an engine is running, PATS has no influence. If you can get the right terminals jumped, with your key on, the engine will fire up.
            • drag214
              drag214 Well-Known LVC Member
              366
              4
              Apr 30, 2009
              California
              It sound like you do have a bad connection either at the relay/fuse box, the starter or a break in the wire between.
              If you have the parts available you could do a pin-drag-test (Test the for sufficient clamping force on the connection on each pin at the socket).
              Inspect the electrical connections at the starter and...
              test resistance of the power wire between the relay socket and the starter solenoid (try wiggling the fuse box while checking for continuity).
              Your problem may be in the starter but this way you rule everything else out.
              • Like Like x 1
              • Knuckles
                Knuckles LVC Member
                14
                4
                Jul 23, 2018
                Hunstville, AL
                This evening after work the old car didn't want to crank again. I pulled the relay and took a jumper wire I had for this occasion, having used it previously with success (thanks milehighmikey). But this time, nothing. No spark when I made the jump connection. I suspect my problem is in the wiring harness. Feels like pulling the relay might be pulling the terminal away from the wire it is supposed to be crimped to. Shoved the relay back in and the car started. This week I'll take the time to inspect the relay connections in the fuse box but I haven't a clue how to reconnect the wire to the terminal if that's the problem. Looks like a real rats next of wire enters the box but I can't see how you would access a detail wire or two.
                Of the five terminals on the relay four make sense to me but the center one I have no clue what it is supposed to do. Until I figure out what to do for a permanent fix I may try to locate a 12V source and connect it to the starter with a push button. With cold weather arriving I need this car to get to work...my Harley isn't adept at negotiating ice.
              Share This Page
