Visalize said:Does anyone know if there is a way to mod the rear windows so that they go the entire way down? I figure its some kind of child safety precaution but I don't have kids. Anyone know anything about this?
Kelleyo said:If I am not mistake I think is has to do with the rear wheel well. The door is not deep enough in the rear to accept the glass.
JPsBored said:maybe you can remove the glass and have it cut
smaller glass will go all the way down, as long as you measure it all correctly.
Quik LS said:how often would you really use this? spend the time and money on go-fast stuff...
eL eS said:Speaking of go fast whats the word on the SC.... I fell off the planet for about a month or so and probably mised out on all the updates.
eL eS said:Yeah but you would be shaving 10 lbs of weight of the vehicle that should equate to a 1/10000th of an increased 1/4 mile time are close huh?![]()
eL eS said:I just roll the fronts down to the same height of the rears. I think it gives a nice symetrical appearance.
too funny! i thought that i was the only one to do that.LennDawg said:haha same crap i do... i get out of the car and make sure the 2 windows line up in the back n front haha
SurfjaxLS said:You know it's bad when you spend a few minutes getting it perfect.
The problem with the window is the regulator assembly. It stops the window before it goes all the way down. When my rear regulator was broken, and disconnected for the big metal plate in the door, the window was all the way down. So, it can be done, but will require some modding.
Quik LS said:got a bunch of new shiney parts last week.
I just have to:
- re-route of the intake vacuum hoses
- re-route the accelerator cables
- re-route all the intake electrical
- tune
so I am now planning all the parts - trying to stay with pre-made stuff as much as possible - so this can be a kit.
Should be a couple more weeks....
2001LS8Sport said:Uh....then the window won't go all the way up.....
eL eS said:So this is a working model then? Excellent! Is this the same SC that they intend t us on the V6?
