Diplomat 1
If anyone remembers I had a ignition coil d code on my 2003 Lincoln ls 3.9 and I checked wires seemed like continuity was good. So I sent pcm to find out that my pcm was good(no misfires at bench test) but they fixed my transmission problem. Anyway I install the pcm along with all new motorcraft spark plugs and replaced the remaining 3 could that haven't been replaced with motor craft coils. Now all the coils are motorcraft. I fire it up and it runs smooth but at idle I still visibly see a misfire. This is actually my dad car and he has been putting regular gas in the car for the longest and I know that isn't right. Could that cause the misfire at idle? I took it for a quick test drive and it seems like the throttle response is good and it actually pulls like it hasn't in years but when in drive and car is stopped when sitting inside the car it doesn't seem like car has a misfire I can't feel it but when in park i can feel the vibration. Timing issue? Could I possibly have messed up my head in some way since I left the car running so long (around 2 years) with misfires and maybe I have low compression? Is that possible ? I know I have a lot of questions please be patient with me thanks.
Other problems I have is I went to go check transmission fluid and I believe I did something wrong. Everything online says to remove the middle screw of the drain plug to check for fluid level. If fluid comes out its good but I did this and about a quart of fluid came out and I believe that's wrong. The way I used to fill it was with car running at idle warmed i filled it thru the fill plug fracking toward the rear of the car and while car was leveled I filled it until I fluid came back out. Is that correct? I feel like since I lost the fluid my car now bangs into from park to reverse and vise Versa. What is the proper way to check for transmission level?
Lastly when I was doin my control arms I took the bottom brake fluid sensor off ( looks like a oil pressure sensor) to get to the arm bolts. Anyway when I first started it pedal would go to the floor and I figured I got air in the system. My question is what is the proper way to bleed the brakes on my car? Thanks so much for any help I know it's a lot
