May LSOTM entries
SPSully
Orangeville, ON
Same as last month. First 5 go to poll then poll stays open till end of month.
please use this format when entering and keep it to 5 pics
January's LSOTM
Fonsito's 2001
2001 Lincoln LS-V8
Exterior:
- 2006 LSE Front Fascia
- 6000k HIDs on Lows
- Nokya Yellow Bulbs on Highs
- 3000k HIDs on Fogs
- McLaren Grille
- Blox Chromoly Lug Nuts
- 18X8 +38 Falken Koblenz
- 245/40/18 Michelin Pilot Tires
- 35% Window Tint
- LED Lexus License Plate Lights
- Light Smoke Tinted Reverse Lights
- LSE Rear Surround
- 3" Turndown Exhaust Tips
Interior:
- OEM Woodgrain Dash Trim Kit
- Broadways Mirror
- Valentine One Radar Detector
- OEM Woodgrain Shift Knob
- Napolex Air Freshner CS-X3
Engine:
- Autospeed Intake System Powdercoated Textured Black
- Samco Sport Black Coupler
- Custom Grounding Kit
- 2.5" Borla Exhaust w/ X-pipe
- Hex STPR Polished Bolts w/Washers
Suspension:
- Sprint Springs
- OEM Shocks
- Energy Suspension Swaybar Bushings
Brakes:
- Front Powerslot Slotted Rotors w/ Akebono ProACT Pads
- Rear OEM Rotors w/ Akebono ProACT Pads
- Stop-Tech SS Brake Lines
- Motul RBF600 Brake Fluid
2000 Lincoln LS V8
Exterior:
19” Fondmetal 9x wheels
50%/35% tint
6000K HID in low beams/fogs
Hoen Xenonmatch 9005 in highs
Cleared headlights
Clear corner markers
Headlight eyelids
McLaren Grille
Lower grille painted black
Custom painted emblems front and rear
Body matched rear surround
Performance:
XCal tuned by KBX Performance (ILLS)
Magnaflow mufflers w/3.5” tips
2.25” pipe from resonators back
Cone filter intake
Drilled/slotted rotors
Stoptech Stainless Steel Brake Lines
Limited Slip Differential
SST shifter mod (reversed the +/- shifts)
Interior:
Whiteface gauges
2001-2002 center console
Kenwood Excelon DDX 7015
Kenwood KNA G510 Navigation
Kenwood KAC9104-D Mono block 1800W amp
Directed audio 600W RMS 12" sub in vented enclosure
Eclipse 5x7 components with surface mouted tweeters in doors
Blue LED interior
Custom Ipod dock/interface
I think that’s it so far.
Here’s the pics :D
You could do that, You SHOULD do that, :D But for the time being it ain't that hard to slap some bondo over those holes and hit it with a rattle can to at least make it look better. :p
I seen pektel's car and was like oh I'll vote for him, but then Rollin's car showed up.....hmm
There's gotta be 3 more that wanna run, right?
Best of luck, rollin.
Pete I love your ride so much...only if I had the balls to go out to paint my top/lower grille :P
Ya i would but theres no chance id stand against those 2..... It will be close i believe
I apreciate the offer. I'd rather not have to pull you out of competition. Come on people, lets see your rides!
come on guys , this is a great idea and remember most of us wont have our cars forever and it would be great to have a calender to keep as a memory.....lets get entered people
Staff online
