Mark Viii head light options
eddiediesel
Queens
I have a 97 Mark Viii OEM HID went out what are my options? And does anyone make an aftermarket replacement headlight for our car?
Best thing to do is buy some aftermarkets from ddmtuning.com, and buy some HID adapter rings from DLF on here... very high quality and will cost you FAR less than buying a USED replacement bulb...
DLF also has an excellent writeup on the install
a used bulb is an option, 80-100 dollars prolly. come up for sale on here from time to time.
Easiest= Buy a used bulb
Smartest= Converting like stang said.
Both cost the same. The retrofit takes a little more work though, but still pretty easy.
Or you could send me your lights for a projector retrofit :)
Or do it yourself.
If you want to buy a used OEM bulb, I've got at least 5 or 6 good ones.
PM me if you're interested.
