I'm about to go through the process of removing my headlights, sanding them down and removing the haze that burdens most Fords/Lincolns. I've seen HID and Xenon Kits but fully understand that these are almost as close to sealed beams as you can get. I know that an HID wouldn't cast properly with a good a quality cut off point. Plus, these are plastic lenses and I've seen what too much heat can do the housings as well as the wiring.
I'd like to go for something a bit different as an upgrade. What are you guys running? I wouldn't mind upgrading the wiring harness (eliminating the switched power) to improve and going with a hyper/crisp white with a bit of a blue hue to it.
Post Pics, Part#'s, etc. A relay harness recommendation would be great. I gave up on Daniel Stern Lighting after 3 e-mails.
Thanks!
:Beer
Thanks!
:Beer
