danny_holtermann
I recently bought a new (used) coolant crossover pipe, had it sand blasted and powdercoated, and like the picture down below there is a small hole right where one of the sensors screw in. but it also looks like to me that it is not a weld but more or less a putty. So here is question numero uno. To fix the whole should i re-weld it from the inside, weld it from the outside, or use some type of putty to plug the hole.
question number zwei, How much pressure actually runs through the coolant lines.
Question number trois what are the two sensors inside the coolant crossover pipe.
Question number vier. Would you replace both the sensors with new ones
