Making progress....sorta
afbryant
Hi again everyone. As previously stated, I bought this non-running project 2004 V6 a couple months ago. It would only run for 1or 2 seconds and die. I took the battery out of my truck and tried it with the same results. But I took the MAF connector off and it will now stay running, surging like crazy , but running. I tried unplugging it before, but evidently this car is super finicky about it's battery voltage
Guys, I feel better about this project now. I am gonna try cleaning it first. Thanks Joe and everyone else. I am probably gonna be needing your experience in the near future
afbryant
Cleaned the MAF sensor and the car will now start and run with it plugged up. It surges with it plugged in or unplugged. I guess it's time to buy a battery and a MAF sensor. Any thoughts?
At least I can get the codes now
afbryant
Took the known working MAF sensor off my Mustang and bought the correct battery for the Lincoln. It will now start and run every time now. We got it off the jackstands and drove it down the driveway. It would only do 12-15 mph along with a some shuddering and surging.
I'm afraid it is going to take a lot of work to get this one drivable. I wish my wife didn't like it so much. Which, I too have always loved the way these cars looked, but I never knew the were so maintenance heavy.
I should have my Forscan today or tomorrow. I hope someone will be able to help me make some sense of it. I have been doing a lot of reading on it myself, but it is a lot to take in
afbryant
Got my Forscan codes, maybe someone can look over these and maybe help me determine what put this car in Failsafe mode. It is the 2004 V6. The car has only been ran probably 30 minutes and only driven 400 yards since the battery has been installed
PCM: P1000-FF ,P2100-FF, P2104-FF, P2107-FF, P2110-FF, P2112-FF
OBD2: P2100-C, P2104-C, P2107-C
DSM-1676
DDM:B1341, U1041, B1676, B1309,
EATC: B1262, B2426, B1676, B1242, B2796
ACM:U2025, U2008
IC: B1318, U1147U1147, B1681, U1041, B1875, B1352U1262
GEM: B1503, U1027, B1676
REM: B1676, P1641
EPB: C1989, U1027, C1409, C1408
ABS: U1009
RCM: B1308
I did this with battery voltage at 12.39 .
P.S>------I just tried it again but Forscan is NOT picking up the PCM codes!! It picked up all modules except the PCM
gips
Bulgaria
The PCM does remember old codes, so better clean them all then start it again and go for a spin. Many of those appear simply , because of battery being removed. You need to cleanup and get the recent ones.
gips
Bulgaria
Could be, i just notice with mine i get lots of U errors when battery is removed. He has plenty of those too :)
afbryant
Forscan got where it would not pick up on the pcm most of the time. I tried a couple different obd2 scanners with the same results. I sent the pcm off to have it refurbished at SIA. It is worth a try. Don't want give up yet
afbryant
Got the call yesterday from SIA. My PCM has unrepairable internal faults. Bittersweet.
At least I know why we could never get it running right. Where do I go from here? Is what I am thinking to myself. Every thing works on the car, even the cooled seats. I am not sure of the trans though, because it has been in fail safe mode ever since I have had it.
What would be the procedure if I decided to try and find a PCM? I have a 04 V6. Have many of you tried to go this route?
joegr
Gulfport
An 04 or 05 V6 PCM should work for you. (An 03 might work, but I would avoid 03 if you have any choice.) You will need the full Forscan to program the new PCM to your PATS module (in the cluster) and your keys. You will need at least two unique PATS keys (can't be cloned) to do this.
I wonder if you have bad coil(s) that killed it. I would be nervous about the cops. I think I would replace them before trying the new(used) PCM.
MIKEBEBE
NEW ORLEANS
Hey man.
That sounds like bad news about your PCM.
Maybe you could experiment with getting one from the junk yard.
I have a 2005 V8 model.
The dealer told me that when those go then you may as well junk the car since no new ones are available.
Good luck with it..
gips
Bulgaria
In the worst case you can go with aftermarket ECU like Ecumaster or something similarly cheap. Most stuff is analog in this car , so it will work fine. Probably the most challenging will be the climate control :)
joegr
Gulfport
Climate control, parking brake, transmission, fuel pump, instrument cluster, ...
Much, much easier to find and use a used OE PCM.
afbryant
Oh well, I only have one key and it is a valet. That pretty much settles it. Thanks guys.
joegr
Gulfport
Valet or not does not matter. You can buy another PATS key and get it cut. (They do not have to be keys that ever worked with your car, they can be new keys.)
afbryant
found a local mobile locksmith that will come and make me an ignition key for $90. Think I will go for it. Hey Joegr, that key and the valet will be good enough for the programming for Forscan, right? Just making sure before I get into this.
joegr
Gulfport
Yes, but you could get by much cheaper.
$10 key from eBay/Amazon, and get it cut using the valet key at your local ACE hardware for $5 or so.
