I am having the same intermittent won't start problem as the person in this thread (LvC Thread 34363) and several other people across the net with my 2000 LS v6. Dealerships have no clue what's causing it even after the owner has shelled out hundreds of dollars to have it fixed. Today all of a sudden mine got worse and started shutting off without warning while the car was running. Instant dead. No response at all but the power was perfectly fine. Radio, windows, interior chime and all were just fine.
In the past when it happened, it usually just won't start all of a sudden but once it starts it runs like a top as usual. The engine is completely dead when you turn the key except for a little clicking under the hood where the starter relay and fuse are. All of a sudden it would start when you turn the key then shut off again without warning. I swapped relays and it started multiple times then shut off. I swapped them back and it did the same thing. (I will be replacing the relays anyway to be on the safe side) Then I stumbled across something very very bizarre. With my wife in the passenger seat and me under the hood, she started the car. As soon as I got in the car it shut off. I got out and she started it back up. Got back in and it shut off. I then realized that these intermittent episodes typically only happen after my wife drives the car, which means she has to adjust the seat. Then it starts perfectly fine for days or even weeks at a time. (she doesn't drive it often) We don't use the memory setting at all. So then I had my wife get in the driver's seat and the car shut off as soon as she got in. Then she adjusted the seat and it started and stayed running until we got home with no problems.
I know that the driver's seat has a lot going on electronically (heating elements, power adjustments, air bag control, etc.) What could be going on with the driver's seat that could cause the car to not start or just cut off spontaneously? This has to be more than coincidence and if I've stumbled across something major like I think I have, then it's no wonder dealer's don't have a clue to what's causing the issue to all of these LS'. There's no way they would link the driver's seat to an assumed engine problem.
Any insight would be most appreciated so I can try to resolve this issue on my own before having to dive into the dealer money pit.
