Well I've decided to get rid of my Lincoln. I've owned this car for a year and a half and just recently paid it off.It has 128k on the clock. $7000 obo. Here's a list of the things that I have done.
Engine
A/C Compressor, orifice tube, and accumulator
Belt Tensioner
Serp. Belt
Alternator
Intake Manifold Gaskets (Each runner butterfly was removed and thoroughly cleaned)
Spark Plugs
IAC Motor
K&N Air Filter (Silencer removed)
Fuel Filter
LMS Chip in computer
Suspension
Upper Control Arms
Lower Control Arms
Spring Conversion (2.5 Inch drop)
Rear Hub Bearings
Front Sway Bar Links
4:10 Rear Gears with Trac Lock
2 brand new rear tires
Monroe shocks and bushings
New brakes all around
Transmission
3500 Stall Converter
Tranny Cooler
Tranny Filter and Gasket
Front Pump seal
Rear Seal
There are 2 small door dings on the drivers side from some idiot parking to close at the mall. To center caps are missing. Tint on all 3 back windows need to be changed. Front windshield has 45% tint. Front drivers seat has small hole in Lincoln star. It is barley noticeable. Car does need a sunroof motor, wiper motor,2 front tires, and washer fluid button. Wipers do work but stay in the up position. It has to be manually put down when shut off. Oil has always been changed with Mobile 1 every 3000 miles. Serious inquiries only. I also have the double x pipe set up which I never installed and the original torque inverter. No trades! 8638991143 or 8633535111 Call anytime.
Engine
Belt Tensioner
Serp. Belt
Alternator
Spark Plugs
IAC Motor
Fuel Filter
Suspension
Upper Control Arms
Lower Control Arms
Rear Hub Bearings
Transmission
Tranny Cooler
Front Pump seal
Rear Seal
