FDPuma said:
			I Have A 1989 Lincoln Continental.  My Trouble Is:
The Car Is Low On All Four Side.  Previous Owner Said Air Bags Are Fine.  Air Compressor Works And Pumps Air But Does Not Raise Car.
Please Help.
Frank
First guess would be a bad compressor and/or leaking rear air struts. The only way to know for sure if the compressor can cut the mustard, is with a compressor pressure gauge. Unfortunately, these are very hard to find and most dealerships don't even have one.
As far as testing the struts for leak(s), you may be able to find a leak with a soapy water solution, but if its really down low, you may not be able to see the bubbles.
What reason does he give to
know the air struts are ok?....have they been replaced?....if so, what kind were they?
Even though the compressor "works", it still has to be able to produce
120 psi minimum to do its job. Say its pumping, but only 75 psi. It won't have the mustard to raise the car up.
Keep in mind that the module or "brain" will only try to make a raising adjustment to one end or the other, but never both at the same time. Also, say the module tries to raise the rear of the car first and can't do it for whatever reason in 90 seconds. The module will give up, turn the check suspension message on, shut down the system and not even try to go further and raise the front. In other words, if the module doesn't fullfill the first goal, it won't even try to do the second.
Try this: Turn the ignition on and listen for a faint double click. Listen to see if the clicking came from the rear or the front(most likely the rear). If it came from say the rear, try putting a floorjack under the rearend, then turn the ignition on. Don't jack it up too high,
just below normal ride height.(if its too high, it'll just vent all the air out) It may pump up doing this because your helping the compressor and doing most of the work. It also may help because the crack(s) in the rubber are sealing up enough to allow the pressure to build.
If you can ever get it up one last time, turn the suspension switch off and drive it. If you have a leak, it'll go down on that corner(s).
http://www.americanairsuspension.com/cont pag.htm
Let me know what you come up with. If you would like to talk about this problem, don't hesitate to call at: 1-423-487-4321.
