loss of power after jmod
Ok I went to the junk yard and got a seperator plate outta 96 and got the gaskets that Max told me to get now is the 96 plate the same plz be the same plate
Yes, you should be good with that plate but unless you drilled the 97 plate wrong or made the holes too big, should be no reason to swap plates.
When you pull out the 97 plate, put them together and check all holes. You can use a Sharpie or something to mark the 96. It won't hurt it.
Well I wanna start over for just in case reasons start fresh u know I gotta tear it back down cuz the guy gave me the wrong gasket again so I called max and he gave me the part number..... I wrote it down and went to my dealer and gave them the number.... and they finally gave me the right one
See, if you would have just ordered them from Maxx, you would have had them in the mail today and you know they would have been right. Just take your time on this try and don't rush it. Make sure the check balls are all in place and no need to over drill the holes. Use the lower HP specs and make sure to remove all the steel burr from the holes you drill. If you have some dielectric grease, use it on your plug-in connections. Hopefully you haven't burned up any solenoids already.
I know now and hopefully I didn't either I only drove it maybe 5 miles like that
Went and put the 96 stuff in I think I fried something cuz its doing the exact same thing and I didn't drill out the holes either...no messages on the message center I'm so pissed right now
