nhandisen
Anybody know where I can get a hose to replace this cracked one?
Well the car is overheating and my guess it's because of that crack. I'm not much of a mechanic so bear with me. Thank you all for all the info btw. Where can I get all the cooling system parts too and can I get em in aluminum as well?
This thing? http://www.lincolnvscadillac.com/fo...13-Re-amp-RE-OEM-Coolant-Outlet-Pipe-GEN-1-V8
Your LS V8 is an 00 to 02?
If so, It's the Upper outlet tube from the cooling system.
8A520 Coolant outlet tube
Genuine Ford Part # XW4Z-8A520-AF
[iurl="http://www.lincolnvscadillac.com/forum/attachment.php?attachmentid=828473041&d=1436153609"][/iurl]![]()
Currently on sale, US $41.26 - UPPER PIPE - FORD (XW4Z-8A520-AF)
from Tasca // http://www.tascaparts.com/oe-ford/xw4z8a520af
~ GLWR
PS: you are going to need a whole bunch of other plastic cooling system parts at this point, wait till you go to refill the system in order to rebleed, the fill neck will crack as you attempt to loosen the cap. You'll need a degas bottle soon also (if not already done) Thermostat housing replacement, go with the Aluminum JAGUAR upgrade.
By that brown looking color of where it snapped, the entire plastic cooling system looks like that on the inside, it's brittle, brown and ready to crack, won't hold pressure, let's air into system, unable to bleed correctly = overheating.
~ just saying![]()
