Lincoln Ls Lowering
iivan
Cali
does anyone have a lincoln ls SLAMMED? Flushed? Dumped? ..Basically a low low low lincoln ls with negative cambers
yes, there are a few...
Here's one of my favorites:
From here:
http://www.cardomain.com/ride/3234092/2000-lincoln-ls
bags and a ton of custom fab work, there is another one on here where the guy put the rear shocks on the front and then made new rear mounts so the shocks where up higher in the trunk. plus the L.Ls has a slammed ls look his thread about his finished car
not very
if your looking for "slammed"
as advertised from LSK:
- Approximate Lowering: Front ~ 1", Rear ~ 1.1"
of all of the springs, the eibach's drop the least.
but eibachs are the only springs out there for the ls
or you can order some custom lowering springs to lower it 2.5''
It will run you like 700 though
dude its real cars not model cars it cost to go custom...
If you run air you'll get it sitting on the ground, but be prepared to spend about 3k if not more if you have no experience in regards to install .you have other options in the way of lowering springs, I have no input on cutting a lowering spring.
I'm going for the VIP look, low and flush to get there this has been my process:
I'm working to get the LS fitted with a new body kit (off the shelf cut up and custom),his will give me a stock suspension height with the kit's "lower bumpers, side skirt sitting)
from there the right height will be figured out (its going to be daily driven kitted slammed and flush so what spring offers the lowest yet capable of driving with out destroying the kit)
then the best possible combo of rims and offset and stretch. I have wheels in mind and by the looks of it after the lowering is done and they are fitted i'm going to have to radius the fenders
Not trying to high jack your thread, I'm just trying to show you if your going to go above just lowering with rims, its a process, the longer you take to measure, research and plan the better the execution will be..
Go for perfect, don't settle for the norm because it easy.
coilovers
I know this is a few years late and you all might have found a good way to lower your LS like you want but here's mine with 16 way adjustable coilovers on it.
$4000 for a custom installed air-ride set up It will sit on the ground.
