seionkelley
If a 1994 Mark VIII comes with LSD why should I replace it with a Trac-Loc?
No stock Mark VIII came with an LSD. Being able to spin both tires doesn't mean you have one, either.
Brake stand it for a few seconds then move foreward and launch it hard. I bet only one wheel spins.
I am fairly sure in a viscous limited slip like the Trac Lok
Yup, im pretty dumb.A viscous LSD is a different type of unit altogether. The Traction-Lok is a clutch type.
Read this, see if it makes much sense:
http://auto.howstuffworks.com/differential4.htm
My understanding of friction modifier is to make the clutches slip more - reduce wear and chatter on cornering.
Unless a previous owner swapped in a trak-lock you have an open diff...which will spin both tires, but that doesnt mean full power is being applied to both wheels.
The only real way to tell is the jack up the car and spin one tire method mentioned above.
Anything else is pure speculation.
My Mustang GT has LSD and when I jack up the car and spin one tire the other tire spins the other way.
